Author Topic: DVM810  (Read 1770 times)
Offline lionelkjhTopic starter
DVM810
« on: July 30, 2017, 02:20:47 pm »
Hello; I have to replace the chip on board of this multimeter, can you tell me if it is well: ICL7106 ??? Thank you for your help (if someone has the schema?)
Re: DVM810
« Reply #1 on: July 30, 2017, 02:25:28 pm »
the following....
Re: DVM810
« Reply #2 on: July 30, 2017, 03:54:09 pm »
Yes it is, but it is the COB version, and a replacement chip is likely to actually cost more than the meter itself. What makes you suspect the IC is faulty, they generally are reasonably robust and survive a lot unless you blow up the input along with it as well.
Offline retiredcaps
Re: DVM810
« Reply #3 on: July 30, 2017, 05:50:52 pm »
You already started a thread on this.
https://www.eevblog.com/forum/repair/dvm810/
And people, included myself responded.  Keep all your posts in one thread.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: DVM810
« Reply #4 on: July 30, 2017, 06:00:18 pm »
