Hi everyone,
I recently strted having some issue with my U1272A. Unfortunately the battries leaked electrolites, i cleaned it up and put it back together but it started behaving oddly when measuring temperatures and resistance, other ranges seems fine.
Basically when measuring resistance with nothing connected it just show a variable high value (in the tens of Megaohmn) and seems to count down (see this video for the described behaviour ), when shorting the leads it seems to do the same but starting from about 3 Ohm and counting down. Checking with another DMM i can see the applied voltage during resistance measuring going down.
On the temp range it displays 46 deg C with 26 deg C ambient temp on a K thermocouple.
Should i consider it toasted or there's something i should try?
[EDIT]: Spelling
