I'm restoring a 1977 Lenco A-50 amplifier (that had a big oops-moment in its life). The guy I got it from told me that he tried to repair it, but he couldn't figure out the problem.
He provided me with a service manual and with a picture of the board with annotations. I immediately noticed a mistake in his notes, a NPN transistor was installed where a PNP part was expected (Q506 in the left channel, part of the protection circuit).
When I first powered the unit on, R507 started glowing red and sparks emitted from Q509. Power transistor Q512 was shorted out, along with most other transistors (and diode D502) on the left channel.
The power amplifier board was severely damaged during previous repairs, traces are gone and components were bodged in. I also found a 30 Amp fuse installed where a 1.5 Amp one should go...
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
I replaced every single transistor on both channels (including the TO-3 power transistors) along with the faulty diode and charred resistor. The traces were patched up and all wire-wrap was replaced with soldered connections.
Now both channels work again,
except for one thing...One particular transistor in each channel (Q503 L and Q515 R) runs incredibly hot (finger burning hot), even if the amp is just idling at minimum volume. I want to know what I can do about that.
Attached is a schematic of the power amp section (with the offending transistors marked).
The parts that I used meet or exceed the spec of the ones listed in the service manual, the following transistors are installed now:
TO-92:
Q501, Q502, Q504, Q505, Q507:
BC639 (NPN)
Q503, Q506, Q508:
BC640 (PNP)
SOT32:
Q509:
BD139 (NPN)
Q510:
BD140 (PNP)
TO-3 Power transistors:
Q511:
MJ15003 (NPN)
Q512:
MJ15004 (PNP)
Both channels have identical components installed.
