Author Topic: Agilent Mystery PCB  (Read 1462 times)
Offline sampler1Topic starter
Agilent Mystery PCB
« on: July 06, 2021, 08:56:25 pm »
Good Day to all,
I came across this Agilent power supply PCB and I am trying with no luck to find out what model # does it belong to??
The markings are
30-04-0001-12
Digital PCB
Rev A
Anyone know  :popcorn:
« Last Edit: July 06, 2021, 08:58:13 pm by sampler1 »
“Electronic devices are powered by white smoke. When smoke goes out, device is dead.”
Offline fzabkar
Re: Agilent Mystery PCB
« Reply #1 on: July 06, 2021, 09:32:50 pm »
I haven't visited either of the following URLs ...
"Agilent/Keysight E3631A Power Supply Secondary Board 30-04-0001-12 Digital PWB"
http://sanhis.irevo.space/Jwm7bm23aX4UP4/
http://fwamor.jorle.space/mjhUbm23aX4UP4/
Edit:
This service manual has no reference to this PCB???
https://elektrotanya.com/hp_agilent-technologies_e3631a_dc_power_supply.pdf/download.html
« Last Edit: July 06, 2021, 10:10:27 pm by fzabkar »
« Reply #2 on: July 07, 2021, 01:27:36 am »
Fzabkar,
Very funny ! Ha ha
Your links are garbage and the E3631A does not use a  separate digital board.
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #3 on: July 07, 2021, 04:02:13 am »
Looks a lot like the board out of an E3646A, but has a slightly different layout, maybe a different variant of the same power supply.
https://youtu.be/qoqpyCbifz4?t=204
Cheers Scott
« Reply #4 on: July 08, 2021, 05:21:09 pm »
Hi Defpom,
 Yes it has the same connection layout as the E3646A but It also looks like it has a lot less components. It does say revision A but could it be so different?
by the way, I'm a big fan of your youtube Videos! Thanks.
« Reply #5 on: July 09, 2021, 03:55:38 am »
Defpom ,
Was Right ! it is from an Agilent E3646A and even better I found the problem with it.
It was not working and the voltages were all over the place when I installed it in an E3646A.  If you look around the net you will see a totally different PCB used in the E3646A , this is why i suspected it was the wrong PCB.
Well anyhow, there is two electrolytic's on the PCB , both read good in value but one was leaking really bad. I replaced it and all booted up fine. Note: The revision A , digital PCB is not what you see in the manuals and not what you will see on the net.
Now to finish the repair. Channel one is perfect and channel 2 is dead. Should be easy enough now.
Thanks all,
The following users thanked this post: TheDefpom
