Mine had a dozen or so parts blown (totaly destroyed) from the 12.1Ohm shunt resistors, the mosfets, several of JFets, the analog switches ics (so14).
Which I replaced all. I think someone connected a high power source to the input which sank a high current.
Now all user interface is ok, power is ok (85V+-, etc.) but I cannot hear relais clicking when enabling output and foremost there is no output voltage whatsoever and display reads random values in Volts and Amps.
For now I have just been probing around for defective analog parts (diode, transistor) using multimeter and thermal camera.
But problem is understanding the circuit is very hard (I am software engineer, not hardware), and there is no schematic.
I will continue again with trying to measure the DAC outputs and maby understand which ground is for what (FCOM, etc).
Usually I repair simple stuff, but I though I can do this, but this is way over my current knowledge.
I tried to get this "LeBassiste" schematic, but alas no response.
If you need thermal images, I can make some for comparison, but it´ll take a while since the device is currently packed away (due to frustration)
I put picture of mine here in this german forum
https://www.mikrocontroller.net/topic/478884
