Author Topic: rohde schwarz SML 02 repair help please.  (Read 2204 times)
Offline eurgencaTopic starter
  • Country: si
« on: December 02, 2018, 10:48:46 pm »
Hello.
I was looking for repair tip for sig. generator sml02 and found this site. So first I want to say Hello to all of you.
So I bought this sml on ebay with broken LCD. After replacing with new I can see that I have more problems :(
After powering up I get error msg.
Module (0/CPU)
Missing data block
10401 / freq data ext
Then sml finish booting up and under error page I have 1 stored error.
315 configuration memory lost; EEPROM data
I check service manual and all info that I can get is that one or more data block is missing. But no info how to repair this. I try with calibration and all tests pass, but error remain. Can someone help me with this error.
Thanks and regards, Sebastijan.
  • Country: si
Re: rohde schwarz SML 02 repair help please.
« Reply #1 on: December 04, 2018, 07:02:25 am »
Hello, again.
I found in manual that exist software SML SERVICE UTILITY, but I can't find it on the net. If someone here have this SW or link where to download, will be very happy.
Thanks, Sebastijan.
Offline analogRF
« Reply #2 on: April 19, 2019, 02:10:24 pm »
Hello, again.
Thanks, Sebastijan.
were you able to find that software or to solve the problem with the instrument?
  • Country: si
« Reply #3 on: April 20, 2019, 08:31:44 am »
Hello.
This SW is for service center only, so probably nobady make a copy and release it on net.
I figure out that configuration error is due to wrong firmware update, but benefit is that frequency go to 3.3Ghz. So it is basically SML 03.
Regards, Seba.
