Hello everybody
I recently purchased a Tektronix 7904. The device was probably lying in the attic unused for a long time. After I opened the device, I noticed that the board for the horizontal deflection was quite dirty (see the picture). First I cleaned the circuit board. Now the device can be switched on. The power supply seems to be ok. The vertical deflection works. but not the horizontal. The two vertical channels are visible on the screen when I take the horizontal circuit board out of operation and when I reconnect it, I don't see anything on the screen. I measured the voltages for the horizontal board, they are all there. I suspect that a short circuit occurs in the circuit board as soon as I connect it to the CRT. Perhaps someone here also had this problem with 7904. I measured the output transistors, they are all ok.
Maybe someone here has an idea what the fault could be.
Thank you
