Hi guys!
I need some help from the experts in here.
I have spent a few days trying to find many issues Im having with a HP 3582A spectrum analyzer. It powers on but all I get on screen is garbage. ALL front panel LEDS are on, no Data Loading blinking, so I know the processor is not running. I have narrowed the problem down to the A7 Processor board, since I have managed to get another board borrowed from a friend whose 3582A works fine and my unit does power up with this board installed.
I have tried my best to find the source of the problem on my board, but nothing helped so far. Here's what I've done on the processor board:
- Tested and replaced all electolytics (the originals were fine but I replaced them anyway since I had already desoldered them).
- Dessoldered all ICs on the board, except for U19, U20, U22, U6 and U1 (the processor itself). I have tested every IC using the TTL/CMOS test function of a universal programmer and all of them pass the test, even though Im not sure how realiable these tests are. U19, U20, U22, U6 are all HP part numbers so I wouldnt be able to test them with my programmer, and Im not sure how often these fail to test them on a breadboard, and even if such test would give useful results since I wouldnt be able to replicate the speed and conditions these usually work on.
- Tested all transistors (there are only 3 of them on the board)
- Tested -5V regulator U24
- Clock signal seems fine at TP1 and TP2
I dont know what else to try or to look for as I have been banging my head on this for a week now
with absolutely zero progress so far...
