Hi
I have an ISDN telephone, the ELMEG CS 410 (S0) which my last months have the following problem:
It is attached to my ISDN PBX, when on the phone, i detach - attach the telephone cord (S0) or when the PBX restart for reason like power failure etc., the phone is DEAD it's not power up !
If i connect the telephone (ELMEG) to another telephone line (S0), it's also dead .
If i connect another ISDN telephone to the telephone cord (S0), it working normally !
If i leave the specific device several days (over 10 days) disconnected from the line S0, when i reconnect to it (S0) it power up and it works !!
Over the past two months, however, without any interrupt (power failure etc) the phone suddenly, it's act like taking reboot but then it's power off with the same symptom as above.
So I opened it and saw the board:
At first glance I looked for bad capacitors but optical all is in good shape.
I want to try to change the capacitors, but i 'm not sure for the exact type because it's SMD capacitors.
Is the following correct ? Pieces >Marking > Type 1x> 3V 470 6.3V -> 470mF 6.3V (?)
5x> m3 10 16V -> 10mF 16V (?)
1x> 45 1 100V -> 1mF 100V (?)
1x> 431 22 50Z ->
?1x> 422 100 6E ->
?Any other suggestion to look for ?
