Author Topic: FLUKE 179 CALL ERR  (Read 783 times)
Offline fawadrjTopic starter
  • Country: pk
FLUKE 179 CALL ERR
« on: February 17, 2020, 09:16:09 pm »
HI , MY FLUKE BATTERY GOES LOW, I REPLACE BUT IT GIVING NOW "CALL ERR"  CHECK BATTERY V ITS OK,, IS IT POSSIBLE TO MAKE FACTORY REST,, OR ANY OTHER  TIP,,
Offline Ordinaryman1971
Re: FLUKE 179 CALL ERR
« Reply #1 on: February 18, 2020, 07:05:06 pm »
Did you try to calibrate it?
Does the error go away if you keep the meter on, can you make any measurements when the message goes away. Is the message displayed on all ranges or only, for example, if you are in DC Volts or Ohm measurement mode?
If you get this message  you have to calibrate your meter...
Offline retiredcaps
« Reply #2 on: February 18, 2020, 09:27:00 pm »
If you bought the meter from an authorized dealer and meet its terms and conditions, return it to Fluke for repair.
The terms and conditions are on page 2 or your manual.
