Hello,
It's me again with nitpicky question.
I have 2 54622D scopes. On one of them battery should be replaced. And on that on which battery should be replaced during first power up i have noticed something which makes me concerned.
So this is the situation:
when i pust "quick measurement" key, on the left corner for a fraction of a second i can see a message "incomplete". Even when the signal is connected. If i push the key again no message "incomplete". Here you can see if watch a video carefully by pausing it:
https://easyupload.io/t9cm2fOn the other scope which does not need battery replacement during first power up there is no message "incomplete" if i push quick measurement key. But when i push it and if i choose one of the options offered such as measure frequency i can see the message "incomplete, also for a fraction of a second and you can see it here:
https://easyupload.io/3h218w But you have to watch video by pausing it. So my general question is: is this behaviour normal or i should be concerned? Interesting, but i haven't noticed that before.
I have a d*mn good eye and as i wrote above i am nitpicky...
Also i have second question regarding E3615A power supply.
Why during powering up the amp meter shows some values?
You can see it here:
https://easyupload.io/r0ycjnThank you guys in advance!
Hrvoje
