Hello franklin,
something is drawing the input towards 0V, not towards these +14.7V, neither -14.7V.
As the input is @7µV after 15min, that's another indicator for leakage to ground.
It's quite improbable that this happens behind Q13, because the 100V range works correctly, and there is a 9.9MOhm resistor in series with the input, instead of only 10kOhm.
You could at first check, if Q13 is leaky, by measuring the voltage across its gate resistor R13.
220µA * 2k = 0.44V should be well visible.
The idea to measure across Q13 from S to D is also fine, but I don't expect anything here.
You can do another test, to rule out that the fault is behind Q13: What happens in current mode DCI, if you connect nothing and switch from highest to lowest range, i.e. 1A down to 100nA?
Is there an overflow, or 220µA, or simply near zero reading?
If all that gives no result, then try something odd:
The only components which could draw the voltage exactly to GND are these 82pF capacitors C22 and C23. From the direction of the current flow, C23 would be suspect.
multi layer ceramic capacitors can be mechanically damaged => cracks, maybe also by over voltage, and then they might also have high leakage currents.
So what happens, applying 10V again, if you tap gently on C23, or cool it down a bit with ice spray?
PS: Well I've got an education as an electronic technician in a German Air Force calibration lab 40 years ago (already
) where I repaired and calibrated hundreds of all kind of multimeter gear, mostly hp.
That habit I kept at university, where we also had a warehouse full of old, abandoned instruments, which I repaired plenty. So I learnt a lot especially from the old hp schematics.
I also bought 'my' first hp3458A in 1989 for my PhD studies, but I did not have the CLIP at that time.
When I finally got my really own 3458A in 2009, I dug deeply down into the CLIP at that time, and also thanks to TiN, I think I have now understood most of the schematics of the 3458A.
Same story goes for the 34401A, which I also bought in 1989 for the university institute, and also another instrument myself, as a reward for my diploma. That 30 years old instrument still works fine, and I was able to help others to repair their 34401A remotely.
Frank
