I'm trying to repair a flight stick (joystick) for the Xbox and this slide potentiometer is broken. I disassembled it and the contacts (?) on the slide (?) are bent. I tried to bend them back but it doesn't seem to work.
- The slider is 60mm x 9mm x 6mm and has 3 contacts (2 on one side and 1 on the other)
- "B103" is written on the underside
- The other working potentiometer shows 6 Ohm - 5.2K Ohm.
Can anybody help me find this? I've searched Mouser/Digikey and can't find a match.
