Sorry there was the wrong log file U-Boot 2010.03 (Oct 09 2012 - 12:48:30)Agilent P510
CPU: SPEAr320
DRAM: 128 MiB
Unknown id: 0xffffff. Using ST_M23P40
Flash: 64 KiB
NAND: INTERNAL ECC 128 MiB
failed: 5 0
nand_bbt: Can't scan flash and build the RAM-based BBT
In: serial
Out: serial
Err: serial
SerNum:MY99999999
Chip: AA Board Rev: 4
init RTC: 2001-02-15 15:44:10.15
Net: No ethernet found.
splash RTC: 2001-02-15 15:44:11.18
Press space to stop autoboot: 0
NAND read: device 0 offset 0x320000, size 0x10000
65536 bytes read: OK
## Booting kernel from Legacy Image at 00600000 ...
Image Name: PBOOT
Created: 2012-05-22 16:06:43 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 38780 Bytes = 37.9 KiB
Load Address: 00000000
Entry Point: 00000000
Uncompressing Kernel Image ... OK
Starting kernel ...
Debug serial initialized ........OK
No RTC on 320
Microsoft Windows CE Bootloader Common Library Version 1.4 Built May 22 2012 09:09:57
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
Reading NAND configuration
System ready!
Preparing for download...
No RTC on 320
Loading image 1 from memory at 0xD0620000
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXOXOOOOOOOXXOXXOOOOOOOXOOXOOXOOOXXXOOOOOOOOOXOOOOXOXXOXXXOXOOOXOXXXXOOXXOOOOOOXOOOOXXOOXXOOXXOXOOXOOOXOOXXOOOXOOOOXOXOOOOXOOOXOOOXXOXOXOXOXXXOXXXXOOOXOOOXOXOOOOXOOOOXOXOXOOOOOOXOOOXOOXOOOOXOXOOOOOXOXOOOOOOOOOOOXOXOOOOOOOXXOOOOOOOOXOOOOX
OXOOOXOXXOXXOOXOOXXXOXXXXOXOOXOOXOOXOOXOOXOXXOXOOXOXOOOOOOXXXXXOXOOOXOXOOOOXOOOOXOOOXOOXOOXOOOXOXXXXXXXXXXXXXXXXXXXXXXXXXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x169BC08, LaunchAddr = 0x80362000
Completed file(s):
[0]: Address=0x80361000 Length=0x169BC08 Name="" Target=RAM
Loading image 1 succeeded.
ROMHDR at Address 80361044h
Preparing launch...
No RTC on 320
Launching windows CE image by jumping at address 0x 362000
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar 8 2013 at 17:05:33
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Mar 18 2016)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000 size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
ERROR: C:\WINCE600\PLATFORM\COMMON\SRC\SOC\STM\SPEARHEAD600\DRIVERS\NandFlash\.\sh600_NandFlash.c line 57: ConfigTimming - Unable to open device registry entry
ERROR: C:\WINCE600\PLATFORM\COMMON\SRC\SOC\STM\COMMON\DRIVERS\NandFlash\.\stm_NandFlash.c line 1043: LLD_GetInfo - Unable to open device registry entry
++SER_Init: context Drivers\Active\10
SER_Init, dwIndex:2
GPIO_Select0 Register 0xB300_0024: 0x80000000
Control Register 0xB300_0010 : 0x00000040
RAS Select Register 0xB300_000C: 0xffffacf4
CORE_CLK_CFG 0xB300_0024: 0x80000000
SER2 got sysintr:0x00000013
SER2 Serial Port, new baud rate:0x1c200 (UARTCLK:83250000 IBRD:0x2d FBRD:0xa)
++SER_Init: context Drivers\Active\11
SER_Init, dwIndex:3
+OALIntrRequestSysIntr IRQ (1) already used by SYSINTR (19)
SER3 got sysintr:0x00000014
SER3 Serial Port, new baud rate:0x1c200 (UARTCLK:83250000 IBRD:0x2d FBRD:0xa)
Incorrect Data, interal ECC failed at 0x62db
OHCI\system.c, GCFG_USBH1_SW_RST
OHCI\system.c, GCFG_USBH2_SW_RST
-EDeviceLoadEeprom 80:09:02:05:E6:FA
Phy found addr 7 (ticks=3917)
WaitForLink Start (ticks=3919)
No Link (ticks=4921)
<--EDeviceInitialize
GMAC DMA status register = 0x0
FAILED to obtain valid Flash Handle in PlatformInitializeResetting the USB-device silicon
sh600_pdd, IOCTL_BUS_POSTINIT
ERROR: C:\WINCE600\3RDPARTY\Agilent\HPP\Common\Drivers\stm320_UsbFnBusDriver\.\ufnbus.cpp line 1137: failed opening \Agilent Flash\SPD\usbOverride
stm320_UsbFnBusDriver, set IST priority 96
#################### dllEntry ###########################
Exception 'Raised Exception' (-1): Thread-Id=04a90002(pth=831ff000), Proc-Id=04a80002(pprc=8327bc3c) 'Torreys.exe', VM-active=04a80002(pprc=8327bc3c) 'Torreys.exe'
PC=400256e8(coredll.dll+0x000156e8) RA=803782c8(kernel.dll+0x000062c8) SP=0002f274, BVA=ffffffff
PC=400256e8(coredll.dll+0x000156e8) RA=803782c8(kernel.dll+0x000062c8) SP=0002efe4, BVA=ffffffff
PC=400256e8(coredll.dll+0x000156e8) RA=803782c8(kernel.dll+0x000062c8) SP=0002efdc, BVA=ffffffff
SSInitialize: Error 3
