Author Topic: M-AUDIO Fast Track Pro repair  (Read 5976 times)
Offline z4ri0nTopic starter
  • Just another Italian emigrant
« on: April 01, 2017, 04:12:40 pm »
Hello guys! this is my first post  ;D
I found this m-audio fast track pro usb interface in a dumpster... just when I was considering to buy a focusrite scarlett, luky day  ;D
I opened it and found that the voltage regulator was literally cut in half, it is a UTC LD1117AL AD. I started to search for it but seems to be obsolete and no one sell it anymore.
I tried to search for an alternative but didn't find a match  :(
can someone help me?
thanks!
Offline mcinque
  • I know that I know nothing
Re: M-AUDIO Fast Track Pro repair
« Reply #1 on: April 01, 2017, 05:22:44 pm »
I would try identifying what ICs are connected to the power rails to see by their datasheets what voltage and current they require, just to have a starting point for a replacement.
You could then remove the part and inject the found voltage to see if there is some short over the regulator before simply replacing it.
« Last Edit: April 01, 2017, 05:43:20 pm by mcinque »
Offline Vicus
« Reply #2 on: April 01, 2017, 05:39:55 pm »
It seems to be a standard ldo regulator. What's the problem? The pinout?
https://www.sparkfun.com/datasheets/Components/LD1117V33.pdf
« Reply #3 on: April 01, 2017, 11:46:00 pm »
I tried to compare the datasheet with other regulators that are in production, but didn't found a good replacement.
here the datasheet for the original regulator: https://protostack.com.au/download/LD1117_A.pdf
is the A version 1A adjustable not fixed.
here the board photos front and back:
it require a 9V DC 500mA power supply, positive inside and negative outside.
I'll try to remove it to understand in which configuration is installed, but I'n not good enough to derivate the complete circuit and do the math to modify it in case was not possible to replace it with an alternative.
« Last Edit: April 02, 2017, 01:47:03 am by z4ri0n »
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #4 on: April 02, 2017, 05:29:36 pm »
An LM1117 in TO-220 will be a drop-in replacement, just find the output voltage, because pin 1(Gnd/ADJ) is ground on the bottom layer, probably either 5v or 3v3.
Offline Gyro
« Reply #5 on: April 02, 2017, 06:04:42 pm »
That's curious damage. The regulator has thermal and overcurrent protection, it looks as if there's a reverse polarity protection diode too. Maybe a severe input overvoltage?  :-\
Looking at the bottom of the board, it looks as if that regulator might have been hand soldered before. Edit: Overheated during soldering?
« Last Edit: April 02, 2017, 06:09:53 pm by Gyro »
Best Regards, Chris
Offline Richard Crowley
  • KJ7YLK
« Reply #6 on: April 02, 2017, 06:12:18 pm »
Looks like a botched repair attempt.
It does NOT look like the original production soldering job.
Mouser sells 50 different shades of LM1117.
OTOH, I wonder if a fault bad enough to crack the regulator in half might be related to trauma elsewhere in the circuit?
« Last Edit: April 02, 2017, 08:38:15 pm by Richard Crowley »
Offline OldNeurons
Offline mcinque
« Reply #8 on: April 03, 2017, 07:20:15 pm »
It seems to me that LM1117AL (cracked on board, evident bodge repair attempt) is not an equivalent of LM1117L (mounted on original board): am I wrong?
« Last Edit: April 03, 2017, 07:25:23 pm by mcinque »
Offline Rasz
    • My random blog.
« Reply #9 on: April 03, 2017, 07:40:33 pm »
all it takes is for that barrel jack to be 5.5/2.5mm type, user plugs his laptop supply and puff
Offline mariush
« Reply #10 on: April 03, 2017, 07:41:38 pm »
The 2 resistors below the regulator set the output voltage.  On trace goes from those to the GND/ADJ pin of the regulator.
The tab is Vout on LM1117, so you can check with the continuity function of your multimeter, the tab should be connected to the center pin as well.
The pin to the right is the input pin.
If you can't find a *1117 , LM1085 or LM1084 should be pin compatible (they're 3A max for LM1085 and 5A max for the LM1084), they can work with higher input voltages (up to around 29v compared to most 1117 which cap at around 17v from memory) and they have same forward voltage drop (actually even better than 1117 chips at high currents, less than 1v at 1A, up to 1.3v at 3a compared to around 0.8v..1v at 0.8A for *1117 )
I keep using *1117 because they're literally made by lots of companies and they use various prefixes.
