So I just ordered this meter and unfortunately I kind find any other american sellers online to replace it...
I opened the meter to add a back light and replace the fuse and fuse holders with proper 1000v buss man cermaic's, also replace some PTC's with higher quality ones. All these mods worked out great, made the meter much better!
Unfourtantelly whie cleaning up some flux I accidently got Acetone all over the LCD, put it back together LCD, worked but it was all bubbled... so next I tried wet sanding the surface with 400 gritt to 2500 gritt wet/dry paper. Next I cleaned the entire thing with alcohol. Let it dry, sit over night. Now segment of the digits and Bar graph are not working.....
Since this screen is a 22,000 count screen does anyone know a part number, for it?? My next option if i want a comperable meter from the US is 130 for a Uni-T71D which is nice but still needs some work in my opinion I would rather just cheaply replace my LCD!
