Author Topic: Chip ID  (Read 961 times)
Offline OpenCircuitTopic starter
Chip ID
« on: January 30, 2020, 01:52:03 am »
Shot in the dark here, but my $20 "Microscope" is in the mail - 1000x even :-DD.  Anyone know what the part number is for this ( see yellow arrow below) or possibly a trick to help make the characters more readable? Only have a head strap magnifier (El cheapo) and still cannot see the letters/numbers to ID this thing.
Might be a CM6800 control board according to this post (reply 6): https://www.eevblog.com/forum/repair/corsair-cx600-atx-smps-made-by-cwt-problems-not-working-need-similar-schematic/
Board is from an ATX power supply on the primary side.
Hoping it has something to do with the primary side not boosting.
« Last Edit: January 30, 2020, 03:09:45 am by OpenCircuit »
Re: Chip ID
« Reply #1 on: January 30, 2020, 06:16:23 am »
I believe it is OB5269CP
« Last Edit: January 30, 2020, 06:40:12 am by OpenCircuit »
Offline DaJMasta
    • medpants.com
Re: Chip ID
« Reply #2 on: January 30, 2020, 06:39:49 am »
A trick to read the letters is to just angle it differently - there are some angles where the etched plastic will be nearly invisible and some angles where it should be pretty clear, provided that it's there.
Online wraper
  • Country: lv
Re: Chip ID
« Reply #3 on: January 30, 2020, 07:11:23 am »
And clean with alcohol first. Laser marking is poorly visible when surface is covered with flux residues.
Re: Chip ID
« Reply #4 on: January 30, 2020, 06:21:30 pm »
Thanks for the suggestions....that is precisely what happened - alcohol cleaning and angle.
I am guessing/hoping internal heat/short made it so hard to read - I need to fix this thing for some odd reason. Something not quite right about the top surface of this chip. I will post a shot with my "microscope" when it arrives in a few days.
« Last Edit: January 30, 2020, 06:26:43 pm by OpenCircuit »
Re: Chip ID
« Reply #5 on: February 01, 2020, 08:55:07 pm »
Does the chip appear to have damage?
OK, I am not laughing any more...$18 "Microscope"! Worth every penny!
« Last Edit: February 01, 2020, 08:57:32 pm by OpenCircuit »
