Author Topic: Help identifying a part  (Read 1114 times)
Offline perdrixTopic starter
« on: July 30, 2017, 10:43:30 am »
I'm fairly sure it is a capacitor, it has colour code bands and text saying "1P0" (I think).
Lead torn off so can't measure it (don't ask!  :-[ ).
Colours look like red, violet, green so it might be 27 * 1E5 = 270nF?  If that is the value, then I'm puzzled by the text marking of 1P0  :-//
Does anyone recognise this and know the value type and voltage rating?
Thanks
Dave
Offline Gyro
Re: Help identifying a part
« Reply #1 on: July 30, 2017, 10:50:48 am »
It's a ceramic plate capacitor - 1pF. The colours indicate dielectric type (I've only seen one colour before) at that value it will be NPO.
It's a very low value, something RF?
Best Regards, Chris
« Reply #2 on: July 30, 2017, 12:07:07 pm »
It was in series with an 18M2 (Brown, Grey, Red, Green)  resistor across a Vishay S102L precision resistor (20K000 0.05%).  This resistor is part of a precision attenuator, and the R and C were mounted under the board.   The other resistor in the attenuator (289.3 Ohms) also has series RC trim under the board  in parallel with it (274K in series with a cap marked n22 AFAICT, so maybe 220pF).
The two main resistors appear in the schematic, but these under board parts don't.
If I had to guess, I would think they are there to trim the frequency response of the attenuator.
RU sure that it's 1pF?  Finding a leaded 1pF cap will be non-trivial.
Dave
« Last Edit: July 30, 2017, 12:18:49 pm by perdrix »
« Reply #3 on: July 30, 2017, 01:19:46 pm »
1pF is common, though you can replace it with a twisted wire adjuster cut to the right length. Easy to get as a NPO leaded part as well.
« Reply #4 on: July 30, 2017, 01:54:43 pm »
I had some 1pF 0805 parts so used one of those.
Thanks, Dave
