Author Topic: Advice needed ,ccfl board,external or placed inside my scope?  (Read 460 times)
Offline nic77Topic starter
« on: January 26, 2022, 01:27:26 pm »
Hi to all ,as my scope's ccfl lamp ,transformer is not working anymore i ordered a small single lamp board ,all i need now is some advice ,should i place the new board inside the scope or place it in a sealed box outside the scope ,greetings to all to all ,nic.
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Advice needed ,ccfl board,external or placed inside my scope?
« Reply #1 on: January 26, 2022, 01:28:43 pm »
ccfl wiring emits a lot of noise, so should be kept as short as possible, i.e.inside
Day Job: Mostly LEDs
The following users thanked this post: nic77
« Reply #2 on: January 26, 2022, 07:29:59 pm »
Thanks Mike ,i have ordered a led strip as well to see which is the best option just going to have to experiment , on the left side of the scope where the monitor is there is nothing,only the power supply board ,and the main acquisition board is totaly to the left ,thanks and the best greetings .
