Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Tektronix 465 no trace
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tektronix 465 no trace (Read 635 times)
Feyman_Follower
Contributor
Country:
on:
October 07, 2022, 06:26:09 pm »
Hello I bought today this oscilloscope: it is in good condition, display illumination lights up also if it is a little flickering, every indicator light turns on, the only big problem is the CRT: it looks completely dead, it shows nothing. I measured the voltages and they are all lower than expected: +15V +11.27V; +8V +5.76V; -8V -6.23V; +5V +4.14V. Another problem is the fan, it doesn't work. Instead the fuse isn't blown. Can someone help me
Logged
mzacharias
Frequent Contributor
Country:
Re: Tektronix 465 no trace
Reply #1 on:
October 07, 2022, 07:41:01 pm »
I'm no expert on the 465, but I have seen an open, even intermittent, bridge rectifier.
Rather than pulling out the board for service, it's possible to wiggle the rectifier until the leads break, then clear the holes and solder in the replacement.
Logged
med6753
Super Contributor
Country:
Tek nut
Reply #2 on:
October 11, 2022, 04:44:11 am »
All of those PSU voltages are referenced to the +55V source. If that voltage is low then the entire PSU will be low. Check the +55V and repair as required.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
