Author Topic: Help Repairing Weller WR3M Soldering Station  (Read 4944 times)
Offline deandadnaedTopic starter
« on: March 14, 2019, 02:45:05 am »
Hi everyone!
A couple of days ago I made a terrible mistake.
I have a Weller WR3M soldering station. The air pump wasn’t working since I bought it. So I thought I could inspect what the problem was and solve it.
However. I made a mistake and now the station doesn’t work at all.
By mistake I plugged the Air Pump (24V CC) to the plugs in the board of the Vacuum Pump (12.5 V CC). After doing that the soldering station stopped working.
Here are some images.
Visual inspection reveals nothing wrong (I think). The fuse wasn’t blown. Nothing seems burned. Still it doesn’t turn on. When I plug it, and turn on the switch I hear a little buzz and that’s all.
Any help is really appreciated. I really like this soldering station. It has been with me for a while and I really want to get it back working.
Thank you!
Enviado desde mi iPhone utilizando Tapatalk
« Last Edit: March 14, 2019, 04:27:24 am by deandadnaed »
Offline mahi
Re: Help Repairing Weller WR3M Soldering Station
« Reply #1 on: March 14, 2019, 05:23:02 pm »
When you speak of the fuse, do you mean the primary fuse at the back of the unit or the 2 secondary fuses on the PCB (the brown and black thingies next to the big grey connector)?
« Reply #2 on: March 14, 2019, 05:28:20 pm »
The fuse I checked was the main one at the back of the unit.
In this picture is right below the ground signal and the yellow/green cable.
« Last Edit: March 14, 2019, 05:37:12 pm by deandadnaed »
« Reply #3 on: March 14, 2019, 05:34:26 pm »
How can I check the fuses on the PCB?
It’s the one that says “MST T3 15A/250V” (black) and the other says “T1 6A/250V” (brown).
Should I check them for continuity?
Offline helius
« Reply #4 on: March 14, 2019, 06:30:08 pm »
You can use your DMM in resistance mode and probe both ends of a fuse. If it reads below 1 ohm, it's good. Anything above that and the fuse is blown (there may be a path in the remainder of the circuit that provides a non-infinite resistance, but a working fuse is always less than 1 ohm, usually much less).
« Reply #5 on: March 14, 2019, 06:44:28 pm »
I’ll do that. And I’ll post the results.
Thank you very much!
« Reply #6 on: March 14, 2019, 07:06:05 pm »
I’ve opened the case and measured the resistance of the fuses. Both give above 2 mega ohm of resistance.
I think that given this results it’s for sure both fuses are blown up. I’ll replace them and see what happens.
Anyway if there’s something else I can do, any advice will be appreciated.
« Reply #7 on: March 14, 2019, 07:39:45 pm »
I’ve tried “bridging” the fuses. And it’s correct. The Station does turn on.
I’ll buy them and replace them. I know That’ll work.
Thank you very much Helius!!!
Offline juhuhu
« Reply #8 on: November 11, 2019, 01:53:15 pm »
deandadnaed Do you have maybe high resolution pictures of the main circuit board of this station? If yes, could you send me in PM. I have one on the table for repair and need some burned components info.
Thanks.
Offline SB
  • Country: ir
« Reply #9 on: January 13, 2020, 06:20:49 am »
Dear Juhuhu;
Did you get a high resolution picture of WR3M board? If no, kindly let me know. I could send you the picture.
If yes , did you repair your damaged WR3M ?
Thanks a lot.
Rgegards
Saeed(Mr).
Offline Brycharlie
« Reply #10 on: June 02, 2024, 09:34:24 pm »
Would it be possible for me to get those images? I'm currently working on one of these. I'd also appreciate photos of the internals of the unit in general. Thank you!
B.C.
