Author Topic: Adjustment for Uni-T UT71E  (Read 3784 times)
Offline jf_EDTopic starter
  • Country: sa
« on: December 03, 2016, 09:14:26 am »
Hi Everyone,
I am having trouble for adjusting voltage and current values of UNI-T UT71E.
Can anyone help me for this matter?
AC values are out of tolerance same as well in the current.
I'm searching in the internet for the schematic diagram of this UT71E, but sadly lower versions of the unit I searched.
thanks for the help in Advance.
Offline retiredcaps
Re: Adjustment for Uni-T UT71E
« Reply #1 on: December 03, 2016, 05:57:05 pm »
What reference or other meter are you comparing to that makes you think the UT71E is out of tolerance for basically every reading?
Please give us examples of your readings.
« Last Edit: December 03, 2016, 06:21:38 pm by retiredcaps »
The following users thanked this post: jf_ED
Offline Lightages
  • Canadian po
« Reply #2 on: December 03, 2016, 06:16:56 pm »
Here are some videos to help, and all the files attached are for the UT71E. Two of them are with a filename for the rebranded version from Voltcraft. I have added another more complete calibration procedure.
« Last Edit: December 04, 2016, 02:42:17 am by Lightages »
  • Country: sa
« Reply #3 on: December 04, 2016, 07:19:05 am »
Thanks for this. Big Help. I tried to adjust all VR's. Before the first calibration, the out of tolerance value is at micro Ampere only, but I already turn every VRs, I think I need to re-calibrate every function.
Again, thanks for this.  :-+
