Soo, i am quite curious if the psu for this LCD could be repaired. Take a look at the pictures what is going on.At first a thought that a cap blew. But that's not the problem I think. All the caps look good.Any suggestions?
no life at all = start with fuse, measure all semiconductors (mosfets, diodes) for shorts
Quote from: Rasz on January 27, 2015, 09:38:56 amno life at all = start with fuse, measure all semiconductors (mosfets, diodes) for shortsAnd do not forget to check if you have the main voltage at the input of the psu.
Did you measure the voltages on the output BTW. Nothing at all?Check if there is voltage on the big capacitor when connected to the mains. If there is check another things on the picture.
The main cap voltage kept jumping... I have no profesoinal multimeter, but I did see numbers from 50to300v.
QuoteThe main cap voltage kept jumping... I have no profesoinal multimeter, but I did see numbers from 50to300v. Main power switch with bad contacts ?
