Hi again,
Sometimes it feels like life is out to get me.
Here is a photo of today's dilemma. I have no doubt it will take you 2 seconds to tell me how easy this was to Google or otherwise find out, but I searched for a while on Mouser, Google, DigiKey etc and could not find an answer.
Basically as you can see in the photo, I have a 51R0 resistor that measures approximately 9.88mm.
However, according to the chart inset, there is no such thing ? 6.3mm is the largest SMD resistor.
Why is the resistor in the image nearly 10mm in length and yet according to SMD resistor charts they only go to 6.3m
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
A bit more explanation......without measuring the pads on the PCB, I get the approximate size in the chart....but I'm working in KiCAD and when I put the footprint down it is too small.
Maybe the problem lies in the KiCAD footprint sizes?
The spec sheets say this is a 1206 size SMD resistor.
When I pick that footprint in KiCAD, the footprint is too small.
It's like I have to custom make a footprint for this...even though 1206 is a very common resistor size.
![I get confused so easily - I cannot find this resistor size](https://www.eevblog.com/forum/index.php?action=dlattach;topic=295706.0;attach=1304990;image)
These kinds of things delay me often and throw hurdles at me. I would imagine no one else has these kinds of problems.
It's hard not to let it drive one crazy. I'll bet this is one of those things that requires a special kind of dumb to not figure out.
Thanks for explaining and please pardon my frustration.
