Author Topic: Xantrex Inverter - Normal Behaviour?  (Read 1203 times)
Online edpalmer42Topic starter
« on: December 02, 2016, 06:34:15 pm »
I picked up a used Xantrex Xpower 1000 inverter.  Typical 12V to 115 Vac @ 1000 W modified square wave inverter.
Everything seems to be working, but I noticed one odd thing.  When it warms up enough for the fan to kick in, the waveform changes; the non-zero part of the modified square wave gets slightly shorter and the zero time gets longer so the frequency doesn't change.  A scope shows that the peak voltage isn't changing.  A non-true RMS DMM shows the change as a significant voltage drop from 120V to 110V.  The output voltage is speced at 115 Vac +-5% so both 120V and 110V are within spec.
This is the first time I've played with anything like this.  Does this sound like normal behaviour?
Thanks,
Ed
Offline arclight
Re: Xantrex Inverter - Normal Behaviour?
« Reply #1 on: December 27, 2016, 03:26:54 am »
Their output waveform will change based on the type of load you apply.  For instance, a transformer-style microwave oven will cause it to smooth out significantly.  I'd look at what is happening when the fan comes on (i.e. refrigerator kicking on, fans, etc).
Arclight
« Reply #2 on: December 27, 2016, 05:55:05 am »
In order to get things warmed up so that the fan would start, I was using a heating element from an electric stove (~43R) to apply about 300W of load.  The waveform didn't change until the fan started up.
