Author Topic: 53131A strange behaviour update  (Read 537 times)
Offline Hrvoje_CROTopic starter
  • Country: hr
« on: May 18, 2020, 06:54:49 pm »
Hello!
Ok this is quite strange and i am confused. I need old experienced electronics guru who can explain me why this is happening.
So i connected my 53131A to Siglent SDG2042X, 100mVpp, 1kHz. The display on 53131 does not update (except if i push RUN key on the 53131A). Ok, so i tried old Stanford Research with same settings and voila! The counter has worked normally. I have filmed this. You can see it here https://easyupload.io/myvo5g . But i am still not sure if everything is ok with my 53131A because of this https://easyupload.io/3sckkj . This happened today even when i did connected 53131A to the Stanford Research generator, but after i tested 53131A on the Siglent first. Strange, huh?
Thank you in advance!
Hrvoje
« Last Edit: May 18, 2020, 06:57:31 pm by Hrvoje_CRO »
Offline awallin
Re: 53131A strange behaviour update
« Reply #1 on: May 18, 2020, 07:00:41 pm »
what are your trigger settings and trigger level?
  • Country: hr
« Reply #2 on: May 18, 2020, 07:12:39 pm »
on my 53131A? Default, i am not sure what exact values. But under trigger sensitivity i didn't change anything if you mean that. Few moments ago i have tested the 53131A, had misbehaving issue with siglent, as i connected counter to the siglent the values on display of the counter had misbehaving, and as i changed the frequency from 1kHz to 10kHz the counter did not the followed accurately frequency update, so i tried the same on other signal generator, had same issue but after few moments the counter had stabilised the readings. Also one important thing: if i connect counter to the 10MHz rear output or rubidium i get stabilised readings with no any issues.
« Last Edit: May 18, 2020, 07:24:14 pm by Hrvoje_CRO »
Offline Dr. Frank
« Reply #3 on: May 18, 2020, 07:31:41 pm »
check your trigger levels, and AC/DC coupling, please.
Unpleasant shaky video, btw.
Also check this BNC cable, and the other channel on your 54131, i.e. BNC connectors may be shaky alike.
Frank
  • Country: hr
« Reply #4 on: May 18, 2020, 07:48:42 pm »
Frank
Sorry for the shaky video. It was only for demonstration.
