Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
LCD monitor motion traing ghosting problem.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LCD monitor motion traing ghosting problem. (Read 839 times)
sdancer75
Frequent Contributor
Country:
on:
September 14, 2019, 11:14:53 am »
The motion trail ghosting problem, is a monitor or video card problem?
If its a monitor problem what kind of part is responsible for this?
Regards,
Last Edit: September 14, 2019, 11:16:24 am by sdancer75
Logged
shakalnokturn
Super Contributor
Country:
Re: LCD monitor motion traing ghosting problem.
Reply #1 on:
September 14, 2019, 01:04:29 pm »
Not sure in your specific case, usually this is the sort of symptom you'll see with a bad shielding.
Logged
sdancer75
Dacke
Regular Contributor
Country:
Reply #2 on:
September 14, 2019, 03:03:50 pm »
Agreeing with the shielding issue shak said. Try moving the monitor/cable around and see if anything changes. If you're using VGA, try replacing the cable.
Logged
sdancer75
Rasz
Super Contributor
Country:
Reply #3 on:
September 14, 2019, 03:57:52 pm »
vga cable?
Logged
sdancer75
sdancer75
Country:
Reply #4 on:
September 14, 2019, 04:46:41 pm »
This is a computer in my work..... So, as soon as I return to work, I will test the cable I will let you know.
Best Regards,
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
