Symptom: Barely ever recognizes disc. Many different discs that play fine in my stand-alone player. Cleaned the discs, cleaned the lens. Same result.
OS: Win 7
Drive: TSSTCorp CDDVDW TS-L633F
Firmware: LE02
Player software: VLC
Tried all the standard "troubleshooting", nothing. There's no malware on the PC, no driver issues. I tried to find new firmware for the drive but by the code it's a Lenovo special, nothing I could find.
Is it possible to know what the stupid drive is doing so I know where it fails? Can I find out the optical power the block is putting out with software?
I installed Opti Drive Control, but it gives high level info. It just says "insert disc"!
when I ask for a test, it seems to want to test the disc, I want to test the drive!
So eventually after rebooting the PC and inserting the disc a few dozen times it eventually sees the disc and plays fine. Even when it plays "fine" it trips up on slightly scratched discs.
The thing is ancient (2011) so all I could find were pulled spare drives.
Yes I still use DVDs, I get to watch tons of stuff from the library! O0 Uh, when it works, that is...
