Wow the list is longer than expected...
Parts to replace if available (and cheap):
CR115 = DIODE, DUAL SWITCHING, BAV99L(SOT-23) [RF-82]
U119 = IC,NEG VOLTAGE REG -15V,500MA,79M15 [IC-195]
U125 = IC,POS VOLTAGE REG +15V,500MA,7815 [IC-194]
R153 = RES NET, 3.6K MICRO DIVIDER [TF-246-1]
U118 = IC, J-FET, OP-AMP, TLE2081CD(SOIC) [IC-967]
R279 = RES, 1K, 1%, 100MW, THICK FILM (0805)
C222 = CAP, 47P, 5%, 100V, CERAMIC (0805)
C146 = CAP, 2200UF, 20%, 16V ALUM ELEC
U111 = IC,CMOS ANALOG SWITCH DG211DY(SOIC) [IC-768]
U109 = IC, 8 STAGE SHIFT/STORE,MC14094BD(SOIC) [IC-772]
U124 = IC,+5V REGULATOR,500mA,7805 [IC-93]
R277 = RES, 66.5K, 1%, 100MW, THICK FILM(0805)
Q118, Q112 = TRANS, NPN, MMBT3904 (SOT-23) [TG-238]
U117 = IC, VOLT. COMPARATOR,LM311M (SOIC) [IC-776]
R278 = RES, 357, 1%, 100MW, THICK FILM (0805) [R-418-357]
R155 = RES, 4.99K, 1%, 100MW THICK FILM(0805) [R-418-4.99K]
R168 = RES, 270,5%, 250mW, METAL FILM (1210) [R-376-270]
VR109 = DIODE, ZENER 17V, MMBZ5247BL (SOT-23) [DZ-104]
VR110 = DIODE,ZENER 5.1V, BZX84C5V1 (SOT-23) [DZ-88]
C145 = CAP, 1000pF, 20%, 50V, CERAMIC (1206) [C-418-1000P]
Q124,Q126,Q123,Q125,Q120 = TRANS, N CHANNEL JFET, SNJ132199(SOT-23) [TG-294]
R280 = RES, 49.9, 1%, 100MW THICK FILM(0805) [R-418-49.9]
R140 = RES, 1K, 1%, 100MW, THICK FILM (0805) [R-418-1K]
R276, R316 = RES, 10K, 1%, 100MW, THICK FILM (0805) [R-418-10K]
U123 = IC, DUAL PICOAMP OP-AMP AD706JR (SOIC) [IC-910]
Q119 = TRANS,P CHANNEL JFET,J270 (TO-92) [TG-166]
U116 = IC, DARLINGTON ARRAY, ULN2003L (SOIC) [IC-969]
CR114 = DIODE, SWITCHING, MMBD914 (SOT-23) [RF-83]
U131 = IC, QUAD COMPARATOR,LM339D (SOIC) [IC-774]
//Around PRECISION REFERENCE, LM399:
Q129 = TRANS, PNP, MMBT3906L(SOT-23) [TG-244]
Q130 = TRANS, NPN, MMBT3904 (SOT-23) [TG-238]
VR112,VR113 = DIODE, ZENER, 6.2V MMS26V2 SOD-123 [DZ-97]
U139 = IC, DUAL BIPOLAR OP-AMP, LT1124C58 [IC-955]
