This post is a long time in the making, I originally started last year when
Dave posted his scopemeter repair thread and its been sitting in bits since then so its about time to stop procrastinating and get it working again. The problem with mine seems minor nothing wrong the screen or anything like that, it has just stopped charging via the mains plug pack but will operate with what's left of the charge in the battery which was new just before it stopped working.
I've confirmed the plug pack is functioning correctly ~17VDC coming out of the "Evil centre negative" power jack. I won't bore you with too many photos as Daves video shows the inside of the meter better than my photos do but the first thing that struck me as a bit strange was that the cooling fan was unplugged from the main board.
I thought there is no way it could have come out of the factory like that but it didn't have any obvious signs that it had been apart before so I kept an open mind.
Things went downhill from there when I took the plastic insulation off the Channel input screening cans and took the main board out of the chassis. There's fresh solder on the board at the power input connector location and it looks like someone has tried a bodge wire to repair the centre pin of the power input connector. Actually I think it could be a candidate in that ugly repair thread which is going at the moment...
Free Electron also suggested checking a small switching transistor V4102 if it wasn't charging, I'm pretty sure its the one I've marked in the last photo and a quick check with a DMM on diode mode indicates its still OK. I think I'm 99.999% certain its just the dodgy input connector in the PCB.
The next issue is souring a replacement connector, I'm in Australia and Fluke don't sell spare parts direct you have to buy via the Australian repair agent. The have quoted me $55 including GST plus postage for the connector which seems a bit extreme for a DC power jack (albeit a rather esoteric one at that). On further thought this is probably why the previous owner did the bodge repair instead of just replacing it in the first place.
I'm not sure if Fluke parts are just expensive because they are Fluke or I'm paying a special privilege because I live in Australia and have to buy through a distributor.
Before I succumb to buying one locally can anyone in the US check what the Fluke price is for this part for me? the details are: X4101 power connector 4022 244 92561
Or even better is anyone wrecking a 190 series Fluke and wants to sell me the power connector?
Thanks for your help if possible.
