Author Topic: HM1800 BT Headset refuses to run off 4v power supply instead of li-ion battery?  (Read 3567 times)
Offline salilTopic starter
I removed the single cell li-ion battery soldered to the circuit board of a Samsung HM1800 bluetooth headset and replaced it with a 4.1v DC power supply.  Unfortunately, the device refuses to power on reliably.  I got it to power on once or twice, but it was performing erratically.  I put the included battery back and it of course works just fine.   I'm using a 5v/1A power supply and stepping the voltage down to 4.1v with an NTE956 regulator and some caps & resistors.  The current draw when using the battery has never exceeded 0.5A when I measured it.
Does anyone have any idea what could be going on here?
« Last Edit: February 09, 2015, 10:24:00 am by salil »
Offline janoc
4.1V looks quite high for a single Li-ion cell. Those are around 3.7V usually. Are you sure you are not giving it too high voltage?
Online Alex Eisenhut
  • Place text here.
3.7V is the nominal voltage. Fully charged they go to 4.2V.
  • Place text here.
What's with the unrelated video link?
Offline amyk
Apparently it's what he is trying to use the BT headset for.
It could be drawing far more current than 0.5A in brief pulses, which can't be seen without a scope.
  • Place text here.
Guess I'm not too patient. I see some unrelated video and I just closed it.
Yeah we'd need to see what this mysterious regulator with "some caps & resistors" actually looks like, how long the wires are, etc. Probably losing regulation because of poor transient response.
And how the current was measured, with what, etc...
Offline Seekonk
I would think the cap at the battery side needs to be a LOT BIGGER.  I suspect it can't handle the surge.
Offline Dragon88
What's the dropout voltage of the regulator? Is it greater than 0.9V?
What's the measured output voltage of your regulator circuit with a 0.5A load?
Offline daveshah
  • Country: at
    • Projects
I don't think that the regulator is an LDO - the data sheet doesn't even give a dropout voltage spec - so the dropout voltage is likely to be about the two volts or so. Have you measured what voltage it is actually outputting?
