Author Topic: 2003 Chevrolet Trailblazer Electrical problems  (Read 3237 times)
Offline kolonelkadatTopic starter
  • Obviously, windows are central to Windows.
    • Force Project X
« on: March 04, 2015, 04:21:53 pm »
I have a 2003 Chevrolet Trailblazer. Every now and then the door locks will rapidly lock and unlock. the heated seat will change temperature. the windows will stutter up and down. Ive been all over the net and have been told a dozen different things. This is not a constant fault. Maybe 1 in 3 drives this error will occur.
I started today with the door panel button module. It does appear to have damage, but Id like a professional opinion.
Ive marked the spots I think are troublesome.
odd white powder
black areas under solder mask
broken? traces
Any repair tips would be greatly appreciated.
Online nctnico
Re: 2003 Chevrolet Trailblazer Electrical problems
« Reply #1 on: March 04, 2015, 04:28:08 pm »
This looks like water damage. You better fix the leak. Using conformal coating may also help but if water continues to leak onto the board it will only be a short term fix.
Offline Zucca
  • EE meid in Itali
« Reply #2 on: March 04, 2015, 04:59:32 pm »
Normally in a car before to touch anything you should read out the OBD codes... have you tried that?
« Reply #3 on: March 04, 2015, 05:34:22 pm »
It drowned. You can repair it, and then give it a conformal coat to protect it from further damage, but you should also fix where it is getting water in. My bets are fia the window edge and through the door latch, along with it coming through inside when you drip on the door itself. Place some sheet plastic to cover the board from the top and sides, leaving the bottom open to allow drainage and the new one will last longer.
the black is corrosion of inside tracks and layers, and the white is from areas which are always 12V supplies that got wet.
    • Force Project X
« Reply #4 on: March 04, 2015, 07:18:22 pm »
I hadn't, because it passed emmisions testing and OBD codes result in automatic failure. But I just checked a few moments ago and it reported "no codes"
It drowned. You can repair it...
I made a particularly sad attempt to remove the solder mask and corrosion. Then put some solder over the top of the bare copper in hopes of preventing further damage. I may have made a mistake in bodging a sot23 to a capacitor. But who knows.
I will leave it like this for now. I dont want to coat it or anything until I know i didnt mess anything up.
 :-BROKE
thanks for the input guys.
