Author Topic: 1996 ROWE CD JUKEBOX  (Read 2217 times)
Offline SeekonkTopic starter
« on: March 24, 2016, 07:11:29 pm »
A friend of mine picked up this CD jukebox.  It worked for a little while giving free
plays and then stopped. It passed basic self test but had stored errors, low battery
voltage. Figured I would start by replacing the 2325 3V lithium battery with a CR2025
coin cell and battery holder.  The board is spacious so I just pryed the spot welds
from the battery and soldered onto the shortened stubs leaving circuit board intact.
An iron would easily fit under the battery holder with enough space to fit in the case.
I've found the battery holders leads many times don't fit into the existing board
holes.  Fired up the unit and it came up with a new checksum error.  Cleared all
errors through front panel and then it powered up with no issues.  Took a while, but
finally found the section in the manual to allow free plays.  Pretty amazing that
the CD mechanism still works on it .  NOTE: Removing battery voltage will revert the
higher level passwords to 0000.  This will have to be done even if the battery is
good to remove previous passwords.
If you have one sitting in the basement and don't have a manual, the following may
help. I made this quick cheat sheet for future reference. This was a trip down memory
lane.  Remember when boards were this spacious?  The connectors are poorly labeled
so this plug identifier is included.
1996 ROWE CD JUKEBOX 3/22/2016
FAULT CODE PROCEDURE
Door switch in SERVICE
Display...... ERROR HISTORY
Press POPULAR
Display...... NO ERRORS
OR...........
Display...... ERRORS EXIST
Press RESET & 0 together,  then 80 POPULAR
Display...... A WARN 14-06 16    (batt voltage)
Press RESET & 9 for next line
Display...... START 13:40 02/19
Display...... END 2:38 02/20
See pages 5-15 for definitions of errors
          5-67 battery schematic
Clear errors see page 5-20
SERVICE
press 0
press 0
enter 0000 (security mode)
POPULAR
hold reset and press POPULAR twice
FREE CREDITS 2-24  2-29   3-11
CONTINUOUS CREDIT
SERVICE
press 0 0000 POPULAR
RESET  & POPULAR TWO TIMES
55
RESET & 9
POPULAR
CENTRAL CONTROL COMPUTER
P6  #1 is blue/white
P5  #1 is orange/black
P4  #1 no connector
P3  #1 is red
P2  #1 is red
P1  #1 is red
P15  #1 is red/white
P14  #1 is purple   UP
P13  #1 is orange/black UP
P12  #1 no connector
P11  #1 L to R white orange blank
P10  #1 L to R white orange blank
P8  #1 no connector
P9  #1 is green
BATTERY CR2025 RIGHT OF P6
