I bought a Transmation 1080 some times ago. The unit was suppose to be working but was partially broken when it arrived. Ultimately my goal was to use this device as a precision (to some extend) voltage and amperage source.
The Device:The unit look pretty old, with the fake wood on the front panel, but it was built in 1991.
The Transmation 1080 was originally used as a process calibrator. It can simultaneously mesure and produce dc volt and amp.
Here's the complete list of features and specs:
The Problems:- The NiCad batteries in the battery pack are completely dead and they leaked a little bit.
- On the output, the Volt range is always at 0. Nevertheless, Milivolt and amp are working.
