The story continues.. Another issue I have not identified till today. While manually switching a 10ohm load into/from the post (playing with settings and watching some nodes on the pcb) I found out sometimes the output voltage drops by aprox 0.9V after inserting the banana into the post. That was not caused by CC setting but a random process.
So again I tracked the stuff and again it stops at the 741. The noninverting input sometimes set itself to a 0.1xx volt. There is the C11 1u (in orig schematics) at the other side of the 7k5 resistor so I thought it is perhaps a faulty capacitor, after removing it happened still the same.
There is the C1* 100n between 741's inputs in the schematics not populated on the pcb, therefore I tried to put there something and after several xx nF experiments I finished with a C3=330pF (C3 in the LTSspice) which was enough and which helped.
I also replaced the 1uF C11 with a 22nF ceramic (C4 in the LTspice).
The latest schematics of the affected part below.
I do not know - perhaps is the 741 somehow faulty or it is a clone..too much issues around it to my taste..
What still needs to be understand better is the RC in the feedback of the 741 opamp..
