Here is a few screenshots of current state. On the trigger board I found a diode that was cracked. It is D517. I looked up the Tektronix part number but could only find it was a signal diode.
I just removed it and tacked in a 4148 for testing.
As you can now see I have trace on channel 1 with the trigger mode set to auto.
Channel 2 as well.
I now have the probe attached and this is the resulting wave form. Either sweep or trigger issue.
I can grab the time base or any other control on the right side of the scope.
As soon as I turn or push I loose trace.
Really does not matter what control I play with on the right hand side I will loose trace. Perhaps it is time to remove boards and give the controls a good cleaning.
Also wanted to add that turning the unit off then back on restores the trace. Trigger knobs also have no effect.
