Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
-10v dc - dc converter repair advice needed
« previous
next »
Print
Search
Pages:
Prev
1
2
All
Go Down
Author
Topic: -10v dc - dc converter repair advice needed (Read 5749 times)
fzabkar
Super Contributor
Country:
Re: -10v dc - dc converter repair advice needed
Reply #25 on:
February 19, 2019, 03:48:40 am »
I believe the idea is to use a single "PDM1-S12-D5-S" module. According to the datasheet, the module's input and output are electrically isolated, so this modification should be feasible.
Connect the Vin and Ground pins on the input side of the module to 12V and ground on the PCB. Then connect the -5V pin of the module to the -10V rail of the PCB, and the +5V pin of the module to ground on the PCB. This assumes that the -10V components on the PCB draw less than 100mA (the rated current of the module).
https://www.cui.com/product/resource/pdm1-s.pdf
Logged
microbored
Newbie
Country:
Reply #26 on:
February 19, 2019, 04:07:06 am »
Ahh, I understand now now!!! Any thoughts why he suggested to use a 12V output with voltage regulator IC instead? Thanks!
Logged
motosega
Newbie
Country:
Reply #27 on:
August 07, 2023, 09:56:44 am »
i made a replacement negative psu module for the tr707, it uses icl7660 negative voltage converters.
https://synth.ewancolsell.com/home/tr707-negative-vibes-10v-psu-replacement
Logged
Print
Search
Pages:
Prev
1
2
All
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
