i already gave you my battery costs and told you that at 14p/KWh my battery breaks even.
And I showed with Figures you could and did not even attempt to challenge with your exaggeration and lies that your battery COST you money but you stick your fingers in your ears and start yelling Na na na like a spoilt kid and try to convince us of more fantasy and make believe.
You want to piss money up the wall deluding yourself you are saving money or the environment, Go right ahead. Probably the reason you can't afford to buy a decent second hand EV you defend with your Cult like zealotness.
Do what you want but don't try and convince me of YOUR bullshit, Lies and exaggeration because I have done more homework and research on this than would allow you to ever get away with such Rubbish and Pipe dreams.
I calculated your battery would have to store 26KWH a day to break even and said there is no way you have a battery that big even before you admitted it was only 10 Kwh nameplate with 8 useable. Even by your own fantasy, your 5000 Cycles is over 13 years payback time AT Full capacity which will never happen. You'd need 15 years bare minimum and by that time the degradation in your pack will mean the actualy useable capacity is down to 6 Kwh or less meaning just the PAYBACK, not the profit time is probably blowing out closer to 18 years or worse. Same as every other battery out there and yours is not different except in some deluded imagination.
I could do the maths again but you would only deny the numbers because they would show you are the one bullshiting yourself.
Carry on saving all this money that exists only in your head but dont try and convince others not high on the green Koolaide you are doing anything but undermining the financial position of yourself and that of your family.
