https://youtu.be/OhnjMdzGusc?t=177Generally using switched rheostat sections and/or multiple motor windings or voltage stages. Using multiple tapped parts rather than one big rheostat limits wasted power in the rheostat.
Some of the stuff from that era was actually rather ingenious. You should read up on it more. ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
It means the excess power is converted to heat in the resistor. That way you can only control motors up to a certain size using such a technology before that resistor burns - not to mention the significant loss of the stored energy in the control alone and the influence of overload on the vehicle leading to direct damage in motor or control (basically no motor protection existed back then). Does an internal combustion engine shred if you try to start with overload?
I mean Ferdinand Porsche came up with a internal cumbustion engine -> generator -> electrical motor as a way to propell tanks (VK 45.01 P) to circumvent such issues. Submarines and trains used to be driven that way too, until it was more practical to directly control power (SMPS style) or frequency (VFD style). In parallel there used to be diesel-hydraulic of course, all that just to be able to control the huge amount of output power as efficient as possible and keep the overall efficiency of the system high. Nuclear reactors in personal transportation left aside, which used to be the hype of the 60´s science fiction.
A system consisting of a internal combustion engine, mechanical transmission and clutch in that time was IMHO better scalable and provided more torque to replace horse carriages.
Without being a historian or trying to start a discussion about it, i guess WWII-logistics and availability to store and deliver energy played a huge role in what was the preferred type of propulsion later on, i guess that shaped the most part of what came to be. A technology adopted by a military also means that there is suddenly
a) an infrastructure
b) a huge amount of people trained to be e.g. a mechanic, i.e. experienced with it, able to repair and maintain that technology.
c) a form of propulsion that does not require a working electrical grid (at least for europe there was a lot bombed away and needed to be rebuilt)
So such decisions always have ripple effects which enable things to work that wouldn´t if thing had come different.
Not to mention that internal combustion engines can run on a wide variety of fuels, e.g. gasoline, diesel, alcohol (ethanol), wood gas, coal gas, natural gas, liquid pressurized gas (propane/butane), heavy oil, just to name a few. Don´t understand me wrong, the environmental impact of these varies, an ICE simply doesn´t run the majority of operating time in an ideal operation point, so even "clean" fuels might generate issues when burned under less than ideal conditions (the problem here lies in the system´s control of output power and the user as well), that´s where an electrical propulsion system has huge advantages.
Sure, but still a HUGE number of people will get caught out.
And IME huger numbers of people park on the street outside their house so that's not possible.
Just for info: there are quite some startups coming up with equipment converting street lamps to charging outlets. So that might change the picture a bit.
And FYI, I"m hugely pro electric cars, and want to get one myself, by the practical engineer in me knows it's not going to go mainstream any time soon, it's not even close.
It´s sad that the range extender (aka plug-in hybrid) doesn´t find as much traction as it should. It does combine the best of both and can even solve some issues by having the ICE run in practical ideal conditions all the time.
Just forget the street lamps! Lets play a bit with numbers. This is from
https://en.wikipedia.org/wiki/Tesla_Model_3 AC charging: 30 miles (48 km) range per hour (240 V outlet, 32 A).
Assuming linear dependency, 48_km/h / 32_A =1.5_km/Ah.
If we assume that the street light is lets say: VIALOX NAV-E SUPER 4Y 400W/240V | High-pressure sodium vapor lamp as the nominal designed bulb in the street lamp we get (assuming power factor 0.9): 400_W / 240_V * 0.9 = 1.85A
So assuming 10h loading time and street lamp for every two car we would get range of:
1.5_km/Ah *1.85_A * 10_h * 1/2 = 13.9_km
...And this with all the power for loading the car so the street would be dark. (Getting LED bulb can leave maybe 100W for loading a car. Assuming 150W led with 20000lm vs. HP sodium vapor with 55000lm).
Doesn't seem too good solution in my eyes.
