https://www.edmunds.com/tesla/model-s/2013/long-term-road-test/wrap-up.html"[...]
Observed Fuel Economy:
EPA estimates for electricity consumption in the Model S were 38 kWh/100 miles, with a range of 265 miles on a full charge. Our best observed range was 230.4 miles and the best projected range was 264.2 miles. The best average energy for a single charge was 238 watt-hours per mile (23.8 kWh/100 miles) and the worst 344 watt-hours per mile (34.0 kWh/100 miles).
The energy usage calculations do not include charge losses, which are 25-35 percent based on our experience with the high-powered wall connector (HPWC)."
Cons: Extensive list of repairs necessary, interior amenities don't match other luxury sedans in its price range, latest active safety systems not available, needs at least a Level 2 charger to make it useful as a daily driver.
Bottom Line: The Model S is a fast, comfortable and technologically brilliant luxury sedan,
but numerous problems with its touchscreen, tires and drivetrain make it hard to recommend.[...]"
List of repairs in 30,251 miles:
"Problem Repair Cost
Suspicious noise Replace first drive unit Warranty
Car died roadside Replace second drive unit Warranty
Suspicious noise Replace third drive unit and ride height sensor Warranty
Car died roadside Replace main battery Warranty
Touchscreen froze Replace main display screen Warranty
Optional 21-inch rear tires worn to cords prematurely Replace rear tires and fix alignment Warranty
Car died roadside Replace 12-volt battery and cables Warranty
Steering wheel creak Shim and torque sub-frame bolts Warranty
Odd noise from undercarriage Rerouted logic harnesses per TSB Warranty
Sunroof will not work Replace broken sunroof deflector Warranty
Driver door opens automatically Replace driver door handle mechanism Warranty
Recall issued Battery shield kit installed Warranty
TSB issued Inspect joints for all lower control arm washers Warranty
TSB issued Update firmware to version 5.8.4 Warranty
TSB issued Update firmware to version 5.11 Warranty
TSB issued Replace front bumper carrier bolts Warranty
TSB issued Install rear upper camber bolts Warranty
TSB issued Replace side motor mount Warranty
TSB issued Replace front floor mats, install rear floor mats Warranty
Left radiator shutter faulty Replace center louvers Warranty
Lug nuts beginning to swell Replace all 20 lug nuts Warranty
Cracked vanity mirror hinge Replace cracked vanity mirror hinge Goodwill
Humming noise at start-up Install AC compressor NVH cover Goodwill
Vanity mirror hinge cracked Replace missing charge cord trim piece Goodwill
Touchscreen froze Manual reset (required 9 times during test) None
Windows lowered automatically Unresolved, happened twice None
TPMS confused Unresolved, happened once None
Condensation in taillight Unresolved prior to sale None
