Author Topic: What are your perspectives on peaceful clean nuclear FUSION projects?  (Read 6907 times)
Offline coppice
Re: What are your perspectives on peaceful clean nuclear FUSION projects?
« Reply #25 on: January 27, 2018, 10:39:58 pm »
I had estimated that by about the 2500s, we'll have to throttle back world fusion production otherwise climate change will occur by sheer force of output power being a sizable fraction of solar output.
Orbital sun shades will probably be a thing by then.
Have you compared your estimates with the ones at https://dothemath.ucsd.edu :)
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #26 on: January 28, 2018, 12:36:50 am »
Looks like a blog of interest, but did you have an article in particular to recommend?
Seven Transistor Labs, LLC
Offline coppice
« Reply #27 on: January 28, 2018, 02:19:38 pm »
His blog articles https://dothemath.ucsd.edu/2011/07/can-economic-growth-last/ and https://dothemath.ucsd.edu/2011/07/galactic-scale-energy/ are well known for highlighting the point at which energy consumption growth would incinerate us all. There are a couple of interesting articles by the same guy about the events which lead him to write these blogs. https://dothemath.ucsd.edu/2012/04/economist-meets-physicist/ is one. They describe how some chance discussions with an economist lead him realise that most economists have no sense that physics sets actual physical limits on growth, apart from resource exhaustion. There are a couple of hilarious critiques of his blogs, where the writer completely misses their point.
« Last Edit: January 28, 2018, 11:39:39 pm by coppice »
Offline cdevTopic starter
« Reply #28 on: January 28, 2018, 02:37:41 pm »
There is this group in Sydney, Australia..
http://sydney.edu.au/science/physics/research/fusion/overview.shtml
I've periodically heard of their work over the years.
There are actually a number of small scale research projects (around the world) which have had varying degrees of success. (but still not achieved net gains in energy as far as I know)
Some of the technologies they have worked with and the stories of these various adventures are pretty interesting though.
Offline IanMacdonald
    • IWR Consultancy
« Reply #29 on: January 28, 2018, 07:19:33 pm »
They'll then demand a gazillion in subsidies to put up giant fans to cool the planet. (Wait a mo, they could just hook up those ancient wind turbines that are still littering the hillsides as motors..)  :-DD
Seriously, a common misconception is that fusion is incredibly hard, and only happens in massive machines. Fusion is ridiculously easy to do. It can be achieved with table top apparatus. Look up the Farnsworth fusor as an example.
The problem isn't achieving fusion, it's getting more energy out than you put in. Part of the problem is that hydrogen has a very low density, and that means the frequency of collisions in a plasma is relatively low. Add to that, the positive charge means the protons repel each other strongly, and will likely just ricochet off if the collision isn't exactly inline. Thus a lot of energy is wasted firing atoms at each other to no good effect.
Compare that with fission using neutrons, which have no charge and so are not repelled from a uranium nucleus. You can see why fusion is harder!
To get a decent return -as in sufficient productive collisions- you need to compress the fuel before heating it. The sun overcomes this by way of compressing its fuel with massive gravity, a weapon does so by using the energy from plutonium fission. Neither of these is very practical for a powerplant.
An interesting idea is the Polywell, which uses a pulsed magnetic field to compress a plasma, in an arrangement not unlike the Farnsworth electrostatic fusor.  One advantage is that this is a relatively small and inexpensive machine (say a 1m sphere) so definitely worth a try.
Then again there are the 'cold fusion' experiments which tantalisingly suggest that there may be easier ways to achieve the compression, by constraining hydrogen atoms inside the crystal lattice of metals.
In terms of fuels, tritium (along with deuterium) is the easiest to fuse, but has the disadvantages of being rare and costly, and of giving off very energetic neutron radiation which would likely damage the apparatus. Deuterium alone is somewhat harder to fuse, but inexpensive and plentiful. It also gives off neutrons, although not of such high energy.
The near-ideal reaction would be between hydrogen and boron, which gives off little or no hard radiation, but needs a lot of energy to make it work. Far more than current machines can apply.
The cost aspect also bears comparison with present efforts at wind and solar deployment. ITER will probably cost somewhere around $30 billion. The current annual wind and solar spend is between $300 billion and $500 billion a year, depending who you ask. So, it wouldn't need all that much scaling-back of renewables expenditure to pay for ITER right now, instead of having to wait a good few years to have the full funding.
Presently, wind and solar supply around 4% of global electricity. When you extrapolate that $500billion pa to how much it would cost to go 100% wind and solar, you see that fusion research is actually a very, very cheap option by comparison.
In view of the potential benefits of success, I think it's crazy not to allocate adequate funds to fusion research.
Offline f4eru
    • Chargehanger
« Reply #30 on: January 28, 2018, 10:50:59 pm »
I got a few square meters of peaceful nuclear fusion energy collecting devices on my south oriented roof.
For me it's the thermal fluid filled kind, not the electron-moving counterpart.
Works very well, very reliable since the time when it finally got hooked up right.
And it's quite low cost also, as a bonus.
Concerning actual research, I think Iter is mostly a joke.
There are many many problems that should have been foreseen, and for which there is no practical solution, so that were just ignored, like the plasma contamination from erosion of the walls, or the disruptions caused by instabilities.
In short : "Ehm, sir, there is no existing material that can be used for the fist layer of the wall." "OK, we'll figure that out later, let's build it first."
So it got into a pointless expensive long term experiment.
« Last Edit: January 28, 2018, 11:55:05 pm by f4eru »
Offline f4eru
    • Chargehanger
« Reply #31 on: January 29, 2018, 06:47:52 am »
Yeah, except there is a catch :
- 300-500 billion in renewables brings about 250GW of new power capacity to the grid.
- 30 billion ITER brings exactly 0W of power capacity. Guaranteed.
« Last Edit: January 29, 2018, 07:17:49 am by f4eru »
    • IWR Consultancy
« Reply #32 on: January 29, 2018, 08:12:30 am »
 300-500 billion in renewables brings about 250GW of NAMEPLATE capacity to the grid.
Offline donotdespisethesnake
  • Embedded stuff
« Reply #33 on: January 29, 2018, 10:27:36 am »
I went to see JET being built at Culham was I was a teenager, there were vague promises of "maybe viable in 30 years", but of course they added the classic fusion caveat "we've been saying that for 30 years".
I think that nuclear fusion as a practical commercial power source will never happen. It's not as "clean" and "cheap" as billed, and not really "unlimited" either except in a purely theoretical sense. it might be useful for niche applications such as military or space where cost is less of a concern.
Even if technical issues can be overcome, economies of scale mean that only very large plants are economically viable, then there are all the risks associated with construction and uncertain future returns which deters private enterprise sinking $20+ billion into a commercial plant. It doesn't really matter if the fuel cost is very cheap, if the capital cost is huge. Expensive maintenance such as replacing liners will kill it, it needs to run 24/365 to recoup cost.
I predict that a few countries will build a prototype fusion reactor with a lot of government subsidy to get national bragging rights, but they will not be taken up by private enterprise.
The alternative designs to tokamak are interesting, but mostly still at a "benchtop" level, and there is little sign these can be scaled up to commercial plants.
I think the paradigm of large centralised plants may be on the way out anyway. Those economies of scale worked well in the coal era (which we didn't really leave yet). Modern distributed power generation can be as efficient, and is more flexible and attractive to investors.
I think the future of technological civilisation lies with learning how to effectively harness distributed low density energy sources such as wind, solar, and not with capital intensive "grand projects".
Bob
"All you said is just a bunch of opinions."
    • IWR Consultancy
« Reply #34 on: January 30, 2018, 05:04:11 am »
I agree. Collections of 500ft tall turbines dominating the landscape everywhere, are the worst example of corporate megalomania.
Offline f4eru
    • Chargehanger
« Reply #35 on: January 30, 2018, 07:12:17 pm »
Bullshit. They are beautiful, cheap, decentralized, sustainable and environmentally friendly energy sources.
« Last Edit: January 30, 2018, 07:24:07 pm by f4eru »
Offline james_s
« Reply #36 on: January 30, 2018, 10:04:42 pm »
I do like the look of wind turbines, I would be happy to live where a field of turbines was the view. Huge, graceful kinetic art that also happens to generate useful energy.
Offline fcb
    • Electron Plus
« Reply #37 on: January 31, 2018, 01:01:42 pm »
Fusion is deep future stuff.  Perhaps 100+ years.  But will be really useful for exploring the galaxy.  ITER is optimistically at least 20 years away from useful results, and then it's going to take another 20+ to build something vaguely commercial - and I doubt there will be the commercial imperative to do so.
I think the vast majority of power needs on earth will be met with wind/tidal and solar - this is starting to happen already.
« Reply #38 on: January 31, 2018, 07:50:56 pm »
Volcanic eruptions happen every few decades or so and and sometimes very seriously reduce the amount of sunshine hitting Earth, changing the Earth's "albedo" - Ash in the upper atmosphere reduces rainfall and wind and has been known to cause spectacular crop failures.
So its not good to rely completely on power sources that depend on the sun, wind, or rainfall (hydroelectricity) as they may go away when you need them the most.
Benjamin Franklin (one of the founders of the US) wrote about this.
Of course, "disaster capitalism" is all the rage now.
It would be good to have a "Plan B" but we have no "Planet B" just planet Earth.
« Last Edit: January 31, 2018, 07:56:35 pm by cdev »
Offline John Heath
  • 2B or not 2B
« Reply #39 on: February 01, 2018, 01:17:20 pm »
A nuclear fusion energy collector of the fluid type not electron ? You mean hot tin roof with some copper tubing but I see marketing potential in your way of phrasing it. I would buy one just to say I use fusion energy collectors to heat my house. With this in mind a big problem with alternative energy sources is marketing with a healthy interest in making a profit. Without profit there is no oil to grease the wheels of capitalism. This was not lost on someone in China marketing solar heat tubes. It is a fluorescent type glass tube under vacuum with a copper black sheet with copper tube filled with freon or other heat pump type fluid. The advantage is heat by boiling and condensing is pumped by the copper tube to a concentrated point at the top of the tube where it can be harvested. There is little loss of heat to convection as the glass tubes are vacuum.  The cleverness of the idea is in the after market. How long are thin glass vacuum tubes going to last on a house roof with kids playing baseball and annual gutter cleaning.  The after market heat pump glass tubes have a much higher profit margin. A replacement O2 sensor for a Mazda at 300 dollars in an example of the importance of after market sales. In short energy with a lower carbon foot print needs to be a business that makes a profit for it to be effective or perhaps realistic is a better word. Everything else is just talk if it does not make a profit.
Offline NiHaoMike
    • Facebook Page
« Reply #40 on: February 02, 2018, 03:20:25 am »
I prefer the kind that processes blockchains. Because everyone knows blockchains are the future! :) You can't buy that off the shelf yet, but they're pretty easy to assemble out of commonly available parts. What I liked the best about the one I have is how fast it paid for itself and the "feel good" factor I get from owning it.
The main drawback? My environmentalist friend Allie Moore is now really jealous of me.
