Hi all. I recently setup a solar panel on top of my garage because I can't get mains to it. Off the panel I have two chargers: one charges an old car battery which I use to power some lights, and the other I hook up to my motorbike when I'm not using it, just to keep the battery topped up.
I noticed that when measuring the voltage coming from the panel that I only see roughly the voltage of a battery, 12.something volts. Open circuit it gets up to somewhere like 20 or so volts.
I was half expecting to see a higher voltage from the panel, because I believe that you need something upwards of 13-14 volts to "properly" charge a SLA battery? I am expecting this because I would expect the charger to step that voltage down to the required charging voltage on its battery terminals.
I just realised that because the chargers are common positive that what I am seeing probably *is* the battery voltage itself.
So I'm wondering, is having two chargers connected in parallel to the same solar panel a good idea? What kinds of problems am I setting myself up for by doing this, if any?
If that's the case, how would I go about measuring the voltage from the panel while a load is connected, or do I just have all of this backwards?
Thanks!
