Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Power/Renewable Energy/EV's
USB fan looks like a resistive load?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: USB fan looks like a resistive load? (Read 1415 times)
Faringdon
Super Contributor
Country:
on:
June 02, 2024, 02:14:22 pm »
Would you agree, a low voltage (12v) DC fan , with a BLDC driver in front of it, looks like a resistive load, and not an inductive load?
Logged
'Perfection' is the enemy of 'perfectly satisfactory'
Andy Chee
Frequent Contributor
Country:
Re: USB fan looks like a resistive load?
Reply #1 on:
June 03, 2024, 06:50:00 am »
It completely depends on the load on the fan blades.
For example, if you stuck your finger into the blades and stalled the fan, what do you think the current and voltage waveforms would look like?
Or if you did a massive long fart into the fan and cause it to "windmill", what do you think the current and voltage waveforms would look like?
Logged
Faringdon
Whales
Super Contributor
Country:
Reply #2 on:
June 03, 2024, 06:59:44 am »
It depends on how much approximation you can tolerate. What is the goal of this approximation?
Generally
you don't approximate active electronics as R or L; instead you add lots of power rail capacitance in parallel so that you can pretend that it's a capacitive load with some varying parasitic resistance.
Do you care about turn-on transients? It will look like a big capacitor.
Do you care about transients during motor load changes? It might look inductive if you try and change the supply voltage because the motor can back-drive the H bridges and act as a generator.
Does the driver support regen modes?
Logged
October 2023: Thoughts on the unreleased Tangara audio player
Faringdon
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
