So, uh, what IS it, exactly?
After the enormous webpage finished loading, all I saw was a few pictures (not nearly as much as should've been downloaded in that time, go figure?), and a little text. Hardly anything of substance. They don't seem to have any articles, any diagrams, anything in depth at all. What a useless piece of Web Two Point Oh-So-Disappointing!
I guess, but again this is a guess because there's so little information there: they're spinning molten Pb-Li alloy (Li would presumably be chosen for making tritium, but the Pb content would only absorb radiation, presumably spoiling nuclear efficiency; so, not sure on that one), so fast that, within its spherical container, a hollow center is formed, like the hollow center where liquid drains through a vortex funnel. But fast enough that it's more or less vertical. Then they somehow or another fire a huge ball of plasma (presumably deuterium and tritium) into that hole, and at same time, implode the sphere, nuclear weapon style. Except explosives would be dumb, so it has to be repeatable, and they use steam powered hammers.
And I guess they claim the hammers are timed correctly, which will be the first large barrier to getting such a system working. An imploding wavefront is not easy to generate. It also has to be intense enough to achieve the required peak pressure and temperature, but I don't feel that intensity is as big a challenge as organizing all that metal to move within microseconds.
Obvious drawback: how smooth is the inner wall of that vortex cavity hole thing? I would expect it's swishy and turbulent. Which means, as it collapses, it's going to be swirling with bubbles of gas and plasma and streams and droplets of metal, probably forming a combined sparking mist of everything stirred together. And fusion would largely take place within small bubbles in this froth.
On the upside, lithium would be quite available in the bubbles, which means if there's an option to significantly boost pressures and temperatures to make fusion of lithium nuclei possible (with whatever's available; Li6 + D = Be8 ==> 2 He4 for example), the power output would rise considerably.
I'd like to know how much peak pressure and temperature they're able to get, and how it compares to other methods.
But again, I'm just guessing.
