Author Topic: PCB-4S7A-01 Lithium Ion protection board won't start  (Read 2092 times)
Offline AlienRelicsTopic starter
    • AE7HD
« on: April 17, 2018, 03:23:21 pm »
Is there something I need to do to start these boards?
I've installed two new boards, PCB-4S7A-01 4S on four cells. The cells are at about 4V each, within a few hundredths of a volt each. But the output from the PCB is zero volts.
I can't link to where I bought the boards, but these appear to be a slightly higher current version of the same thing.
https://www.alibaba.com/product-detail/led-panel-pcb-printed-circuit-boards_60395421986.html
Is there something special I need to do to get these to work? Or a specific order I need to solder the cells to the boards? Because of the way they are laid out in the pack (I'm replacing a bad board), the simplest way is to solder B+, B-, then B3, B2, and B1 last.
Steven J Greenfield AE7HD
    • AE7HD
Re: PCB-4S7A-01 Lithium Ion protection board won't start
« Reply #1 on: April 17, 2018, 03:36:49 pm »
I answered my own question....
I connected the power terminals P+ and P- to a generic power supply set at 14.8V@100mA, and the PCB has started working.
