Author Topic: Q Factor for offline CCM Voltage mode flyback  (Read 1201 times)
Offline FaringdonTopic starter
« on: July 17, 2023, 06:49:19 pm »
In AN57, Power integrations say we must take Q = "0.15 to 0.3", when calculating the power stage transfer function.
(as part of feedback loop analysis)
However, TN-203 by Microsemi.com, on page 8, points out that the Q factor is by w0/Q = R/LE
where
LE = the effective inductance.
The microsemi one takes into account that  its the load that is damping the Output LC....so it must be correct.
Where are Power integrations getting "0.15 to 0.3 from?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline mtwieg
Re: Q Factor for offline CCM Voltage mode flyback
« Reply #1 on: July 18, 2023, 01:09:06 pm »
I can't find a coherent definition of Q in either document. And I wouldn't assume both would define it the same way, and therefore wouldn't expect them to suggest similar values...
I don't see this, do you expect everyone to read these things top to bottom for you? And relying on the load for damping is very poor practice IMO.
Impossible to say without a coherent definition of Q. That app note shows an additional LC filter on the output of the flyback, so assigning a single Q value to the entire thing doesn't seem reasonable.
The following users thanked this post: Faringdon
