Some more news related to this project for anyone wanting to take a deeper look.
https://arena.gov.au/projects/realising-electric-vehicle-to-grid-services/https://www.abc.net.au/news/2020-07-08/act-hooks-electric-vehicles-up-to-power-grid-in-research-trial/12436224https://www.anu.edu.au/news/all-news/new-lab-to-help-drive-australias-low-carbon-energy-futureI'd agree with the sentiments the price for the hardware is a bit premium compared to what a well cost optimised solution could be even with "early adopter premium". I did some investigations on cost effectiveness of vehicle to grid (V2G) vs dedicated battery systems.
A 9.8kWh residential energy storage system (ESS) from LG chem is rated for a
24.3 MWh lifetime throughput down to 60% rated capacity degradation (
https://solarjuice.com.au/wp-content/uploads/2018/01/lg-chem-lv-resu-limited-warranty.pdf) with a retail cost of AU$7,862.80 (
https://www.ecoelectric.com.au/shop/lg-resu-10-lv-battery-system.html.html). So thats
0.326 AU$/kWh then you need to add a seperate inverter-charger which would serve the same function at the $10k wall wart vehicle to grid (V2G) interface.
As an additional datapoint for residential ESS, Tesla Powerwall 2 is warrantied for
37 MWh down to 70% rated capacity degradation (
https://www.tesla.com/sites/default/files/pdfs/powerwall/Powerwall_2_AC_Warranty_AUS-NZ_1-0.pdf) at a retail cost of AU$10,000 (
https://www.ecoelectric.com.au/shop/tesla-powerwall-tesla-14kwh-battery.html https://www.tesla.com/en_AU/powerwall). So thats
0.270 AU$/kWh and you've got extra capacity at the end of warranty compared to the LG Chem and the inverter-charger is built-in too.
Now for EVs the standard warranties appear to be about 160,000 km = 100,000 miles (
https://www.caradvice.com.au/859099/electric-car-battery-warranty/) finding how much energy throughput that relates to though is a bit more challenging.
Nissan leafs are warrantied to have after 100,000 miles no less than "9 bars out of 12" (
https://www.nissan.com.au/owners/warranty/new-vehicle-warranty-terms.html https://owners.nissanusa.com/content/techpub/ManualsAndGuides/LEAF/2018/2018-LEAF-warranty-booklet.pdf) and confusingly the first bar segment is 15% but the remaining are 7.5% (
https://cleantechnica.com/2020/01/26/2018-nissan-leaf-60000-mile-update/) so down to 60% capacity. EPA rating for the 2018 leaf (
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=42085&flag=1) shows 187.709 miles for 44.8318 kWh of charge input (probably some onboard converter loss in there) so
4.19 miles/kWh then that gives warrantied throughput of
23.9 MWh or only
532 cycles?! Looks like using your car for ESS is probably not too great in terms of warrantied life. However, I've seen anecdotal evidence the actual lifetime in general is better than warranty at 92.5% capacity for 40,000 miles (
https://cleantechnica.com/2019/01/06/40000-miles-with-the-2018-nissan-leaf/) then 86.8% after 60 000 miles so on track to a bit under 80% by 100 000 miles.
The Australian 2019 leaf (2018 leaf everywhere else) is about AU$50,000 (
https://www.carsguide.com.au/nissan/leaf/2019) then add on the AU$10,000 wall wart so assuming you used the warrantied throughput purely for V2G that'd be
2.51 AU$/kWh (2.09 without wall wart).
Now obviously you're paying for more than just the batteries when you buy a car. It took some digging to find but the cost of a replacement battery for a Leaf is apparently at least is JPY 820 000 aprox. AU$10,700 for a 40kWh battery (
https://global.nissannews.com/ja-JP/releases/180326-04-j?source=nng&lang=ja-JP) and only available in Japan at that cost apparently so that's actually 0.867 AU$/kWh or if we dont include the expensive V2G grid tie (which you could assume as a non recurring cost?) thats
0.448 AU$/kWh not too bad. Mind you, you costs are a bit worse using this guy's quoted cost (
https://forums.aeva.asn.au/viewtopic.php?t=6077) AU$ 10,000 for replacing a 24 kWh battery in a first gen leaf (which were notoriously bad btw,
https://www.greencarreports.com/news/1109640_lessons-learned-from-early-electric-car-2011-nissan-leaf-at-90000-miles) and you might end up getting stiffed by dealerships like this guy (
https://autoexpert.com.au/videoblog/astonishing-30k-nissan-leaf-battery-replacement-bill) with a $33,000 bill for what seems to be the same replacement as the bloke on the AEVA forum... Might be worth looking more into these wildly varying replacement costs.
If the cost of the vehicle to grid interface gets brought down to a more reasonable ~$2.5k like other existing inverter-chargers (
https://www.outbackmarine.com.au/multiplus-48-5000-70-100-inverter-charger-victron) and you assume the EV batteries get degraded maybe half as much as they would driving (i.e. halve the lifetime energy throughput cost) then you could,
maybe justify the lifetime costs with respect to a typical ESS system and have the benefit of not needing to spend extra capital to buy a separate 40kWh battery system.
Again, I'd expect degradation to not be as bad as calculated here particularly considering ESS use where the load characteristics will be much gentler than driving (500 cycles seems low for any cell put under typical ESS use). That being said, the warranty is the warranty and EV manufactures don't seem to have warranties covering V2G use yet so I'm just playing with numbers here.
In the end, I think in terms of straight cost effectiveness its not possible to beat the cost optimisation of a system designed specifically for ESS and at $10k you can literally just buy a Tesla Powerwall but it could maybe work and make sense in the future even with lifetime cost considerations?
Disclaimer: I'm involved in work on EVs and ESS related systems but not any V2G products... as of writing this.
Edit: To compare the loading of ESS vs driving. The Tesla powerwall is 5kW continous, 7kW peak and the wallbox Quasar is spec'd at 7.4kW. That's a
0.185 C load at max with a 40kWh battery. The Leaf's power train is rated at 110kW=
2.75 C with 40kWh battery and obviously you're not going to be flooring it continuously but burst loads an order of magnitude larger.
