thanks, i suppose we will have to build a converter, and check the ITH voltage at no load...or light load....and progressively load it till it overloads, and see the range....then hope that all the other parts do the same thing. As you know, you need a diode in the pull down of the ITH pin...so if zero duty cycle correponds to around 1v or so then thats good..eg in ucc28c43 where the 2 internal diodes mean zero DC is around 1.4v.
