Author Topic: TVS protection for hi side IGBT in SMPS?  (Read 1867 times)
Offline FaringdonTopic starter
« on: January 15, 2022, 10:43:33 pm »
If you have a 3.6kW Half Bridge SMPS, using IXER35N120 IGBTs (fsw = 20kHz) .......then is the P6KE18CA TVS going to be good enough to protect the IGBT Gates from transient overvoltages?
The Abs Max of the gate voltage is 20V.
IXER35N120   IGBT
https://www.mouser.es/datasheet/2/240/l518-1548005.pdf
P6KE18CA   TVS
https://www.littelfuse.com/media?resourcetype=datasheets&itemid=3ba2705e-3e6f-49cc-b247-92bd0aed9fd5&filename=littelfuse-tvs-diode-p6ke-datasheet
Is it  right that we are to consider that  P6KE18CA's  TVS current goes linearly  from 1mA at 18.9V  to 24.2A at 25.2V?
If this was the case, then at 20V, the  P6KE18CA TVS would conduct up to 4.2A
'Perfection' is the enemy of 'perfectly satisfactory'
Offline T3sl4co1l
    • Seven Transistor Labs
Re: TVS protection for hi side IGBT in SMPS?
« Reply #1 on: January 15, 2022, 11:58:22 pm »
What transient voltages?
Seven Transistor Labs, LLC
The following users thanked this post: Faringdon
Offline David Hess
  • DavidH
« Reply #2 on: January 16, 2022, 12:56:05 am »
Assuming that you are driving the gate to full saturation with 15 volts, sure, the P6KE18CA will work fine.
« Reply #3 on: January 16, 2022, 11:41:37 am »
Thanks, its just the general "malaise" thats going to find its way through the IGBT stray junction capacitances and potentially blow up the gate.
Thanks, it seems amazing that this P6KE18CA can only draw 1mA with 18.9V across it, then with 20V across it it can draw 4.2A.
I wonder how a zener in the same package would perform?
Offline David Hess
  • DavidH
« Reply #4 on: January 16, 2022, 02:31:20 pm »
A zener would work the same since they are essentially the same thing.
Offline T3sl4co1l
« Reply #5 on: January 16, 2022, 06:05:27 pm »
That's why you don't take inverter designs from Jimmy Carter.  Mine simply don't do that...
Such an element might be gainfully employed to protect the gate driver, such as in a modular system where the drivers are relatively expensive, and IGBT destruction can't be avoided through other means (or multiple layers of protection are desired).
Offline jonpaul
« Reply #6 on: January 16, 2022, 08:09:52 pm »
Bonjour David: A TAZ is a large area Zener specifically rated and tested on standard pulses with defined wave shape, current etc.
TAZ have specified clamp V and certain currents, but cannot dissipate long-term. The large die in a small package was developed at General Semi decades ago. Yes they are Zeners but not interchangeable!
In the case of gate protection, a TAZ is not usually needed and a Zener can serve as the current is limited by the driver.
Beware of the Zener shunt capacitance on the driver performance.
Bon chance
Jon
« Last Edit: January 16, 2022, 08:11:46 pm by jonpaul »
Jean-Paul  the Internet Dinosaur
