For some odd reason I need to connect a banana plug to a EHV cable. It's low current and I got no other option available. Basically it's to replace a cable from a CRT rejuvenator that is kind of different from most and also uses the anode connection. The part that connects to the CRT is practically 30Kv, as is normally the case for most bigger tubes and it's connected with an anode cap (though I've seen some PVMs that use some weird things...), but the part that connects to the tester / rejuvenator is actually a freaking banana plug! And yes, the original cable that came with it was like that, the unit is totally original. It's from a reputable brand in Germany that has since closed doors.... Doesn't matter, the thing here is I couldn't find any banana plugs speced to 30kv, so probably the device didn't work at that voltage either... Or maybe it did, IDK... But I wanted to use a secure connection without much hassle at the same time.
Anyone knows a source ? I'm tempted to try a simple audio plug at this point, but so far have resisted it, there probably would be sparks everywhere ...
Even the anode caps on the CRT side that connect to the flyback transformers sometimes produce sparks despite having been well insulated when the sets were produced, but as the rubber dries out some start to buzz.....
